Kolher 22hp engine oil?
West Virginia...
Hello everyone, what type of oil do you all use in your engine?
Getting time to change the oil and filter for the summer months...
Sorry guys, yes it is the 7000 series, a 2018 Cub Cadet Lawn tractor
Wow, Is this the first oil change? If not, hopefully, what oil have you been using? Maybe there’s no need to do anything different than what you’re doing now…🥴
Good morning, no it's not the 1st oil change, I been using Penzoil in mine for years, and was just wondering what everyone else uses in there's ?.........I change mine usually before the first time I mow my grass, and change it the same the following year......
When you're pulling that much horse you need the finest oil you can buy..
Yeah, that's why LL-01 or MB229.5x for me. MB takes 9 qts, there's a qt left in one of the 5qt jugs for OPE. BMW takes 7 qts, leaves 1 qt to use in OPE and 2 qts to save for next BMW change. Then I also had an extra qt or two of HPL Euro. The little guys get treated good.
Same here..... after all my Kohler 33 hp takes only 2.7 quarts so why not?
