A friend of mine has a CC with single cyl. Kohler engine. vintage 1983. It has toasted 4 coils in 4 years, the latest lasting about 3 weeks. Failure has been an open on the coil.
Talked to the small engine guy, he indicated if the key switch is bad (like still on when turned to off) and the points are closed, the coil gets cooked. He replaced the most recent coil for free, and I tested coil/ground when the switch is off and there is no voltage. (not sure how to check if the points are closed; I don't even know where they are)
Questions are:
Is there any other scenario that can cause coil failure?
Should coils fail this regularly on OPE This machine VIBRATES (1 cyl) and the coil is under the hood which I imagine runs hot.
Thanks
-Thomas
Questions are:
Thanks
-Thomas
