Kohler SAE 10W-30 Universal Engine Oil ?
Ohio, U.S.A.
Is Kohler SAE 10w30 Universal Engine Oil a full synthetic oil?
Can I switch from Mobil 1 20W-50 Motorcyle full synthetic to the Kohler SAW10W-30 Universal Engine Oil without doing damage to the Kohler Magnum 20HP engine in our Gravely 4-wheel LT?
Reason I am asking is the engine is "noiser" at idle after running for 2 hours at full throttle mowing grass than than what it sounds like at idle during a cold startup.
Thank you for your experiences.
The noise is because the oil has thinned out (as it should when it runs in an air cooled engine), and oil pressure/film thickness has decreased some. I would not worry much.
