Kohler 26hp bent starter shaft
Laurel Springs, NC
I have a Craftsman with a 26hp Kohler engine. Over the last few years I have gone through about 6 starters. While starting if for any reason the engine kicks back or locks up the shaft bends. In 2015 a member "Oldesel" posted how he replaced the 25hp Part# 32 098 04 like mine with a Kohler 27hp Part# 25 089 09 which has a cast support at the bendix end. My problem is this, my gear is 10 teeth. When I look up the starter he used it says it is 9 teeth. It also looks like the Kohler 27hp Part# 25 089 09 is now (Kohler 27hp Part# 25 098 09) unless his post had a typo. Has anyone gone through this and upgraded to the stronger starter? I also found a starter (KH-25-098-09-S) which looks like it may work but some sellers list it as 9 teeth and some list it as 10 teeth.
My thought is I would add a push button by the ignition switch that kept the ignition off until the engine was cranking at full speed. This prevents kickback. Then I would release the push button and if it did not start apply choke. A good battery is always a good thing. Some of the cheap low cost batteries have very little lead in them. Get the good one.
Rod
Problem is likely to excessive valve clearance, making valve timing off, reset lash and try
U will need to pull specifications
This all started to happen with less than 50 hours on the engine. I do have to pull the choke and as soon as it starts release it and it usually works 99.9% of the time. It's just that once so often that it jams. The started shaft is weak at less than 1/2 inch in machined areas. I did find one with 10 teeth that has a full cast housing and bushing support at the shaft end. However I not 100% convinced it will fit, still checking.
