Kitchen counter transmission rebuild
Suburban Washington DC
Hardest part was just getting it up on the counter. Have it out for a clutch job on my Honda Insight and figure I'll go through it and address common issues.
The inside of the aluminum case half's are clean but will get the oil out with the parts washer then rinse with hot water. Then bead blast the outside for appearance sake. Follow with hot water rinse. No nooks or crannies so any risk of leaving behind grit particles inside?
Would enjoy a picture of what you have on top of the cabinets rather that seeing the transmission on your kitchen countertop.....
We’ve been down this road before.
Which suggests this is transmission fluid.
Not mold.
