Received my third extended warranty for my 9 year old Kia minivan, this time for stripped head bolt threads in the 3.3L V6 block causing a blown head gasket / coolant consumption condition. I've actually read about this failure on forums over the last couple years, which has been getting more common and more attention (lots of Reddit posts now). I was keeping my fingers crossed that this only affected the USA-made Sorentos and that my Sedona (Korean made) would not have the issue. Seems that is not the case, but the extended warranty covers the failure up to 15 years / 180K if it ever occurs. Since this is not a clear safety issue (that might warrant a recall), I give Kia some kudos for acknowleding it and putting my mind at ease. This is a $5K-10K repair depending on if they put inserts in the block or replace the engine.
The last extended warranty campaign was for the multi-function switch (turn signals / wipers / etc. assembly). Wife actually had this fail in that the headlights would spontaneously turn off at night. They were good about replacing it for free, although I have to bring it back because they reassembled it with the steering wheel off center. I could see this being escalated to a recall if they weren't proactive.
First one was the power rear doors may fail to close correctly, or operate erratically. Wife thinks she's experiencing the beginnings of this issue.
Curious if these extended warranties are common in the industry. I've owned many different makes/models over the last 20+ years, and other than straight up safety recalls (which are more common in the first few years of ownership), I've never received extended warranties for other makes, despite some having clear cut issues that affected the whole model range. Surprised to see Kia sending these out for vehicles approaching 10 years old, especially the expensive engine issue that isn't clearly related to safety.
