Kerosene powered Briggs and Stratton?
Wonder if these engines are available in usa still.
Ken
I see engines honda clones on google search through abata. $76 USD but the downside lot of ten minimum order and shipping port of shanghai.
They are 8.0 to 1 compression ratio.
Does anyone have parts diagram for kerosene fuel system.
years ago i forgot i filled the lawnmower gas can with kerosene, and i accidently put it in a small brigss engine on a lawnmower cutting the high grass under load it would knock like crazy. but just running at 2000-3000 free spinning the blade it was fine. and i remember it was very hard to start. kerosene has no knock resistance, very low octane, and it also has (high vapor pressure?) whatever the term is meaning it doesn't vaporize as easy because its the vapor that mixes with the air for combustion.
The two head gaskets lower. compression. ratio to prevent denotation. that will reduce if not get rid of the knock under load. ran the b&s 3.75 spirit on diesel last weekend for ten hours plus. It was kinda a torchure test. since it has severe carbon build and only one gasket. i have to clean head and install. two new gaskets.
Ken
Ken
You're on to something..
You could raise squish with thicker base gasket or grind the cylinder, run a hotter plug, adjust air fuel mix and convert small engines to diesel/kero......but other than post apocolyptic survival scenarios, and/or boredom....why?
I went out and pulled the information from my Briggs manual;
Special spark plug # 291835 to be gapped .030
Two head gaskets are to be used
Reduce breaker gap to .015, then the engine must be retimed
I did a quick search to cross the Briggs number but I couldn't get any returns, so good luck!
I read about this in a 70's dealer manual and it said something about starting it on gas and switching it over to Kerosene and back to gas. The two head gaskets was part of the process.
My concern would be fuel dilution from the kerosene not burning completely as that is what happens if you add diesel to a gas tank in a car and most diesel stuff has 18:1 compression or higher.
I was quoting the manual, the older Briggs were adjustable at the coil as to advance/retard the timing.
This wasn't something new or revolutionary at the time the manual was printed as spark plug engines have been running on kerosene since the 20's to my knowledge, more than likely much before that.
We still have a John Deere A, vintage est 1931. It has a one quart tank intergrated into the main fuel tank designed for gasoline, and the main tank for kerosene. It has a dual valve in the fuel line to switch between fuel supplies, you started on gas then switched to kero.
You had better remembered to switch back to gas prior to shutdown because it is almost impossible to start on kero, even at 90f as this tractor is old enough to NOT have electric start, you start by opening compression relief petcocks on the heads then roll the flywheel to start. I had MANY revolutions on this tractor when young as we used it well into the 80's to mow and plow snow.
I wouldn't worry about fuel dilution as these engines are almost indestructable and the directions for switching come right from the manufacturer.
Briggs also stated to expect 15-25% reduction in power running on kerosene, and also approx 20% reduction in fuel consumption.
See the High Speed Internal Combustion Engine by Sir Harry...Ricardo
He built a tank engine running on kero, 186c.i. per pot, 6 pots, and was achieving modern Lycoming BSFC results.
