Get yourself a pump and do a UOA with Terry at 6 months. That should give Terry enough data to tell you how much mileage you've got left.
The M1-105 Xref's to a K&N HP-1005
HP-1005 Product Specifications
Product Style: Oil Filters
Height: 3.49 in (89 mm)
Outside Diameter: 3.81 in (97 mm)
PSI Relief Valve: 11-17
Anti Drain Back Valve: Yes
Weight: 1 lb (0.4 kg)
Product Box Length: 3.81 in (97 mm)
Product Box Width: 3.81 in (97 mm)
Product Box Height: 3.49 in (89 mm)
This is the same filter (M1105) in Wix
Part Number: 51381
UPC Number: 765809513815
Principal Application: Chrysler (83-93), Eagle (89-93), Hyundai (86-89), Isuzu (81-85), Mazda (89-90), Mitsubishi (83-96), Renault (84-87)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.141
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 13-19
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 275
Max Flow Rate: 9-11 GPM
Nominal Micro Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Now without a model/make/year/engine I had to guess and assume that you have a newer Nissan and not one that takes the 3/4-16 thread (aka something like a 1992 Stanza)
Here's what Wix puked out for a Nissan Altima
Part Number: 51356
UPC Number: 765809513563
Principal Application: Acura (02-06), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-06), Infiniti/Nissan (96-06), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-06), Saturn (04-06), Outboard Marine Engines, Various HD Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Nominal Micro Rating: 19
Gasket Diameters
Attached 2.475 2.173 0.233
So the gasket is a little off, but I wouldn't worry too much about it since many filters that xref show this difference in my travels. That is, if you plug some Donalson filters into Wix the Donaldson may have a 2.4x" OD gasket while the Wix will have a 2.8x" gasket in their number ...or the other way around sometimes.
