Ooops I was thought you said your pressure would climb 5psi then drop back to where it was at sustained high rpms. Well if it doesn't drop thats ok. But if I were you I would still hook up a mechanical guage to see how accurate/what your real pressure is. I know 45is enough for close to 6k rpm, but you also don't have alot of leeway either. My friend's 97 Z gets 55-60 at WOT. He uses AC Delco filter though Im not sure which one. His hot idle pressure is about 22psi. He uses 10w40 Penzoil dino oil. I have another buddy with a 95 Z with 103k and his gets the same as yours except he gets more at WOT. He gets oil changes at grease monkey so im not sure what filter he has.
Jason
Jason
