K@N Drop In Filter vs. OEM or Fram Filters
Maumee, Ohio
I had a K@N drop in filter in my Chrysler 300 but I"m thinking it may be passing more dirt into my car than what I thought it would. I think it was a big mistake, as my oil analysis wasn't good when it came to high silicon reading(abrasive dirt) also had some high wear metal readings.
How long ago did you put in the K&N? Did you recently clean it? A clean K&N will probably allow much more dirt to pass than one that has been in a while.
A lot of people have great success with K&N filters, but I prefer just using a paper element. They only cost $10 or so for my truck. No cleaning, no possibility of over/under oiling.
Fram air filters are great in my experience. They have nice thick gaskets for a really good seal, and they are not overpriced. I have had Purolators that didn't seal well due to thinner gaskets. If available, I usually get the Tough Guard since it's only about $2 more and has a light coating of oil and a glue strip to keep the media from getting deformed.
It was brand new and I ran it over 10,000 miles. I was using Mobil 1 extended performance oil and filter. So one oil change and oil anaylsis all on that filter..I put the K@N in the same time I did the oil change. I put an STP Air Filter in the other day and the dam seal wouldn't stay in the air box and when I latched the clip it broke. The gasket wasn't up to spec(when gasket was in the grove the filter would bow up in the middle, that little mistake cost me $80.00. I then went an put a Fram Tough Guard in, as it was readily available, it fit good and snug with no issues. I will run it for 12,000 and pull it. I will do another oil analysis to see if the Fram lowers my silicon levels.
Thanks for the Thread. If you know of anyone that wants a K@N Filter that fits a Chrylser 300, 3.5 liter let me know..The filter has been clean and I have the recharging kit..$ 25.00...
I've tried paper, foam, and cotton (both oiled and "dry-flow"). I never saw any performance gain from the so-called high performance filters so I have always gone back to the OEM paper -- I'll stick with better filtration if it costs me a few HP.
Get an AEM DryFlow filter instead. 99.47% score in ISO 5011 fine dust test. AEM is affiliated with K&N Engineering.
No, AEM just uses K&N filters that are re-branded.
They (AEM) make very few filters for domestics, whereas AFE makes their dry gauze filter for most performance domestics.
Right back at 'ya --> Spring of 2009 K&N acquired AEM's intake related operations. My AEM filter arrived in a box bearing a K&N shipping label. AEM is in fact a subsidiary of K&N Engineering since the acquisition.
