Hi All,
Following on from my thread the other day...
https://www.bobistheoilguy.com/foru...ected-aw55-50-plan-of-attack#Post5329373
My week has turned out a bit different and I've not started what I've planned.
My Wife is now using the car full time doing around 100 miles per week.
I was having a look through my stash last night and buried in the back, unopened and covered in dust I found 5 litres of this...
https://www.eurocarparts.com/p/triple-qx-atf-dexron-iii-1-litre-522776012
I'm wondering if it would be remotely suitable to start off my drain and fill procedure as a sort of pre-flush before I use my intended fluid being Comma MVATF Plus.
I'm thinking of weekly drain and fills as...
Week 1 - Check current level (assumed current fill is factory fill after 13 years and 134k). Top up as necessary. Wait for gearbox to cool, drain, measure and refill with the same quantity compromising of 1 pint of Seafoam Hydra-Trans and Dex III.
Week 2 - Drain & Fill Again with remaining Dex III.
Week 3 - Drain & Fill with Comma MVATF
Week 4 - Drain & Fill with Comma MVATF
Week 5 - Drain & Fill with one 10oz bottle of Lubegaurd Red and Comma MVATF and double check final level.
Anyone think of any reason the Dex III may cause any issues as a quick flush only?
