Originally Posted By: Max_Wander
Originally Posted By: 02zx9r
any conventional will get you 5K but i understand your concerns with the fuel dilution issues. cant remember if it was PP that handled fuel dilution better than others or another one. honestly cant remember
Did you just recommend a conventional for a fuel diluting turbo charged application? Isn't that a bit gutsy?
i did but also understand his fuel dilution issues. he said he will be doing 5K intervals and mentioned a conventional will get him 5K intervals. he can also do conventional and change out more often if the fuel is really that big of an issue.
Why would you make a recommendation if you don't "remember"? These kind of things confuse people who are looking for real answers. Please don't post just to post.
Here is Max Wanderers post:
if you want to change out your break in oil before break in is completed, you'll want a good moly rich oil. Motorcraft, Havoline or Pennzoil?
They once had good doses of moly, not sure about now. Getting a layer of moly on the new engines internals is generally the reason manufacturers recommend running the OE fill for the full length, because the next OCI is not guaranteed moly as part of it's chemistry. Knowing that makes it really easy to think around that problem.
He does not remember if they have lots of moly in them or not. Make sure you ask him not to post just to post!
Funny, when I typed that, I knowingly put myself at risk to getting calle just like you. Moly content could have recently changed, I can't just overlook that. I dont have all the answers, so i must disclaim, but I know they once all had moly and still may. And for the record, it's Wander not Wanderer
Originally Posted By: RI_RS4
Max,
Really now? VW/Audi factory oil does not contain Moly. Occasionally a little Moly from assembly lubes show up, but quite often no Moly shows up in the 1st UOA.
I suppose I was alluding specifically to Honda break-in rationale. Theyre prominantly leading the "leave the FF in for the full term" camp. They insist you leave the moly rich FF in until all surfaces are effectively "plated". I suppose that could be a small contributing factor that allows their engines to wear so well (that and the leisurely torque production
roger , wander
ooops, that is a post just to post i assume, sorry
