JHZR2
Staff member
Hello,
As I recently bought a house, I bought a husquvarna 323L straight shaft weedwacker.
It is a great unit, with a LOT of power and nice smooth running. Im like echo typically, but got a *** deal on the 323L... and Im happy for the most part.
My one issue is that this is the first time Ive used a clutched trimmer. I thought that due to the fence and driveway layout of my property, it would be nice to have, but I dont have enough big stuff to cut to make good use of it. The top-quality string they put on there takes everything out first pass, and so I barely need to give it gas to move the head and then my trimming is done... I only trim what the mower misses, so its not HD cutting.
So in reality, my only peeve is that I wish that it didnt have the clutch. Oh well, its a nice machine, and Ill make do.
However, I think Ill switch to a much thinner string. Even if the head does not feed properly, its OK, for what I do.
But it makes me wonder... the engine will rev a lot easier when there is a lighter load on it, due to a lighter string. Will it have the ability to rev higher compared to a heavier load/thicker string? Will it be able to over rev?
How wel governed are these 2-cycle engines? if I use a light string to not cut everything with such a vengance... will i be doing no favors to my engine and drivetrain, in the instances where I do rev it up high, etc?
I hope this makes sense...
Thanks!
JMH
Thanks!
JMH
