Originally Posted By: hominid7
Originally Posted By: G-MAN
In the rest of the country I think everyone got along fine running 20w20 or SAE 30 year round. And no matter where you lived, too thick oil was a starting issue in severe cold. I don't think there was a rash of blown engines each winter due to thick oil.
I guess my point is that modern 0wXX and 5wXX oils were and are the product of a quest for reduced operating friction and the resultant improvement in fuel economy. From a mechanical failure standpoint, absent near arctic conditions, modern engines will do fine, IMO, on straight SAE 20 or SAE 30 year round.
NB: I went to the grocery store last night around 11 pm. My Chrysler 300M has Valvoline SAE 30 in it and had been sitting all day. The temp was 33F and it started right up like it always does with no unusual noises or protests. (In fact, as I have posted before, startups with SAE 30 are actually quieter since I don't get any bearing rattle on the initial startup rev.)
Just some food for thought...
How many 1930 Fords went 300,000 miles before requiring major engine work? I'm guessing none
Using SAE 30 year-round in areas with temps below 32*F/0*C in a DOHC engine with a modern oil pump will shorten the life of said engine, in my opinion.
Now if you want to substitute 10w30 for the recommended 5w30 then more power to you, as i dont think it would be a problem in most circumstances.
However if you choose to continue with the SAE30, by all means keep us posted. It will be an interesting real-world experiment. I'd be happy to be proven wrong!
I'm switching to 20w20 at the next oil change. If for some reason Valvoline stops making 20w20 (which it's been rumored they will), I'll probably use SAE 30 spring, summer, fall, and 10w30 in the winter.
