Just did upper oil pan gasket
pennsylvania
Well if some of you remember i posted here about my catalyst converter problems a while back in my 2002 nissan maxima. I replaced my front cat, ypipe, and upper oil pan gasket. Not to bad of a job.
The upper oil pan is actually a layer of factory silicone. A hole nissan.
Also deleated the rear cat in the process. sorry no pics too tired from this job.
The upper oil pan on those cars is very difficult and time consuming. You were brave to take that one on yourself!
it wasn't too bad. if anyone did an older 3.0l v6 maxima its extremely similar. although removing the front cat would be best. gives you a bit more room when removing and reinstalling the upper pan.
kia sorento timing belt is next.
