New to boat maintenance so I knew to come here first for the engine oil.
Here is the suzuki spec:
Quote
Suzuki oil meets the National Marine Manufacturer Association (NMMA) Four Cycle Water Cooled (FC-W) standards. The actual oil recommendation is: SAE or NMMA FC-W 10W-40 (operating in temps from 14 degrees to over 100 degrees F) or 10W-30 (operating in temps from -4 degrees to 86 degrees F) API or NMMA FC-W Classification SE,SF,SG,SJ. For temps below -15 degrees F use SAE or NMMA FC-W 5W-30.
I'm seeing some discussion about Diesel oil. Any recommendations there? I'm in the South Carolina so want to cover the high temp range. I also run the full rpm range - up to 6000rpm every now and then so want something that isn't going to foam. Any knowledge appreciated. I like buying my oil from Walmart but I don't want to cheap out if it's a bad idea.
Quote
