Originally Posted By: chad8
It looks like all I could find was sierra and amsoil in a 10-30.
Amsoil is the better oil , I am sure.
There were no FC-W oils back in 2004.
The FC-W standard was introduced by NMMA after the amount of anti-wear additives in automotive oils was reduced in 2006 in order to protect catalytic converters. The latest automotive standards are even more restrictive. FC-W oils have more in common with 2004 automotive oils than the oils that are designed for modern cars.
Most diesel oils would likely meet FC-W standards. But not modern automotive oils.
Because outboard motors have no catalytic converters additives can be used that can't be used in automobiles. So indeed the FW-C spec oil may have a better additive package or more additive than API spec oil for cars. BUT... outboard motors are different than car motors and could benefit from different or additional additives. Your typical car motor likely sees very little use over 3000 RPM. Most cars cruise down the highway at 60mph at less than 3000 RPM. Outboard motors can live a considerably larger portion of their life over 4000 and even 5000 RPM or higher.
Synthetics have hydrocarbons that are uniform and share similar sheer characteristics. Synthetics resist shear better than conventional oils for longer periods of time. In conventional oils some of the different size hydrocarbons break down earlier than others reducing the ability for the oil to protect the engine. Synthetics also vary in quality but that's for another topic. Just because a synthetic doesn't have a FW-C seal on it doesn't mean it does not meet the spec for FW-C oil. It likely far exceeds it.
As far as marine motors running higher rpm's then car motors your correct. But oil's like Rotela t and others , have been used in motorcycles that rev higher then 4-5krpm,plus they run the oil thru the trans. HDEO'S have been proven to be able to get beat up on, and still show good used oil analysis. I would use one in an outboard without question.,,
