I have a very nice, though old, JD GX75 with a Kawasaki 9.0hp engine. This engine uses no oil & does not smoke, it starts every time & is perfect for my yard. I have used a good 30w oil & change it every year at the beginning of the season, should this be good enough or should I use something else?
Last season due to the drought, I only mowed 6 times, the year before 18 times & it is only 2 lots to mow.
One other question, is there a way to check the fluid in the trans axle as I have never found any info on this?
Thanks
Thanks
