Okay, a quickie background on this question. Purchased a John Deere D140 lawn tractor mid season 2015. Changed out the factory fill at the prescribed 8 hours with Mobil 1 Extended Performance 10w30 and OEM filter.
In early December of 2015 there was a second oil change at 28 hours total, or 20 hours on the oil. At this point a larger Wix 51348 filter was added along with more Mobil 1 Extended Performance 10w30.
2016 has been a dry year in my area. The machine now has only 50 hours of run time, or 22 hours on the oil and filter. It is unlikely to exceed 25 hours on the oil and filter this season.
The owner's manual says to change the oil every 50 hours or 12 months, whichever comes first. Given the use of Mobil 1 Extended Performance, TBN shouldn't be a problem. Given the use of an over-sized automotive filter, filter capacity shouldn't be a problem either.
My thoughts are that this motor is still breaking in, and therefore, needs an oil change. What are your thoughts???
