Came from the plant with 27X8.5R15 R3 Carlisle tires.
The tractor is solely used as an aircraft tug. The hangar is smooth concrete and the ramp and helipad are brushed. It's tire time. The R3 tires do not grip well on the smooth concrete and are wearing out fast from the brushed concrete. I was considering R4 tires for wear resistance but they may push worse on the smooth hangar floor. I could add additional weight.
I was also considering some 215/70R15 tires; my thought process is that they will grip better on the smooth concrete floor without buying additional weights for the front. They're also significantly cheaper for what I consider very light duty use for this tractor.
Thoughts?
Thoughts?
