Donald
Originally Posted By: oilboy123
Do your own load test. Disable your ignition and crank the engine while watching the voltage reading. I think 9.6 is what you should be at. If 9.6 or more should be good to go.
That might give one a rough idea, but you really need to put 1/2 the CCA of the battery for 15 seconds and look at the voltage for the last second. Then temp. compensate the reading.
