Got another jeep.
98 Jeep 4.0L
130k, first 100K was put on original owner in 3 years
so I doubt he change the oil enough cause that would be like at least 4x oil changes a year w/ a quality oil. Second owner 100k-130k seemed like he was good about maintenance and knew what he was doing.
Oil pressure seems decent, it stays at 40psi most of the time, but sometimes will drop to 20 psi at idle in the heat. It does knock some, and you can hear some lifter noise. no obvious leaks or oil consumption
I did the first change today
Castrol GTX HM 10w-40 w/ an oversided FL-1a Motorcraft filter
I also bought some rotella synth 5w-40, but was kinda scared to put that in cause I heard of problems with it clearing out too much crud at once.
now for my questions:
1) does Auto Rx seem worth a shot, or a waste?
2) can I mix the rotella t and castrol GTX HM 50/50... or which one is better to run
98 Jeep 4.0L
