Jeep 3.7L and ARX
Northern Illinois
I have a 2006 Jeep Liberty with 3.7L engine and 42k miles. It is
out of factory warranty, bought used from a trusted Jeep dealer at 26k miles while under warranty. During the warranty period it used from 600 to 700 miles per quart during a dealer oil consumption test(s) using recommended conventional 5w30 oil. Chrysler said 600 miles per quart is acceptable. I did not get any warranty resolution from this, but discovered during last winter’s cold weather that the oil consumption went to closer to 1000 a quart of 5w30. I changed over to 10w30 Valvoline High Mileage conventional 10w30 oil. My son's 2002 Liberty with the same engine recommends 10w30 for warmer weather. I have used that grade in Valvoline High Mileage for the last three 3K mile oil changes. I'm convinced that the newer 5w30 Chrysler (year round) recommendation is only for EPA mileage considerations, not engine longevity. I can't believe the factory clearances have changed that much since 2002, but the factory tolerances may have improved.
There are no OBVIOUS puffs of smoke at or funny noises at start-up.
I have found black, sooty, non-oily residue in the cold tail pipe. It looks like old fashioned carbon black from a kerosene lamp. This must be from burning oil, although I can’t easily tell from following my Liberty that any smoke is coming out.
This car may have sat for a while on the dealer’s lot and moved to and fro while not warmed up during the spring of 2008. I understand such treatment can cause difficulties with oil ring fouling, but I am not certain now how that could have been detected at the time. I can’t (wishful thinking) believe that the upper end drain-back channels are already clogged shut.
I bought two bottles of ARX and did a oil/filter change with
10w-30 Supertech. I added a full bottle of ARX. I will probably need to add at least a quart of oil, diluting the ARX concentration during the cleaning phase. The engine takes 5 quarts with a filter change.
1. Should I add two ounces of ARX with each new quart during the
cleaning phase? The ARX instructions appear silent about this.
2. I am using 10w30 Supertech and a Supertech filter during the
rinse phase. Is the additive formulation of Rotella 10w30 also OK for the rinse phase?
3. I looked on the Shell and Valvoline web sites. I haven’t been able to tell where Group II and Group III designations come into play. Is this something that I have to interpret from the specs and MSDS?
This is a semi-last gasp of sorts for this car. Any advice will be greatly appreciated! I do not look forward to having the tightly placed valve covers removed for inspection. Likewise with an OHC configuration, changing out the valve stem seals will be quite a chore. Piston rings? Oh no ! My other car, a 1999 Jeep Cherokee 4.0L, has over 105K miles (96K of them mine) and runs like a champ burning no oil at all between changes.
Visiting this site is like going to school again in a most pleasant way. Thank you for reading this far!
If you don't add the RX with top up oil you just get a waker and weaker solution. That's why I add RX to the oil jug not the engine so any top up oil has RX in the correct ratio.
My Cherokee has a black sooty exhaust pipe all the time.Burns no oil and just passed it's 2 year E test with flying colors at 280,000km.Using a quart of oil every 1000 miles is not acceptable to me.I don't think your engine is dirty or has mechanical/seal issues.It just hasn't found the oil it likes.Since summer is here I would try one oil change with a HDEO like Rotella or Delvac and see what happens.They both come in a gasoline approved 5W-40 weight and I would start there for the summer.If that seems to make your Jeep happy then in the winter a 0w30 weight would be great.Those oils are made for heavy engine shearing and high heat in diesels so your gasser would not put much of a dent in them.
That is much easier than using my graduated "shot glass" measuring tool. It is graduated in fractions of an ounce, but is a bit prone to make a mess.
Better to mix in bulk when using in bulk!
Thanks!
Menard's sells both 10w30 and 15w40 Rotella which I understand are not synthetic and can be used for the Auto-Rx rinse phase. It is still very warm here through October. If my 2500 mile cleaning phase change comes in October, I'll use 10w30. The synthetic Rotella 5w-40 seems to be okay from the various threads for the winter, but not for the Auto-rx clean and rinse phases.
...snip...
"My Cherokee has a black sooty exhaust pipe all the time."
...snip...
BTW, I agree that even 1000k miles per quart is not good. My Cherokee's tailpipe is just dirty in comparison, not sooty.
Thanks!
Makes you kind of wonder why the 4.0 liter staight six was put out to pasture. I guess it was too reliable. What kind of fuel economy does the 3.7 have versus the 4.0. Its kind of hard to guage in that the Cherokee likely weighs close to 1000 lbs. more?
The ARX will surely clean up the ring packs. Usually ring fowling occurs more between the top and intermediate compression rings.
Any chance of PCV valve and plumbing not operational?
Is the motor running too rich from a air fuel mix, leading to high fuel dilution?
I would just stick with the Supertech for the rest of the application. With great knowledge of that shot glass, I think you a prime candidate to free pour an ounce directly into the oil fill hole when adding a quart of oil.
The 2006 Liberty is heavier by a few hundred pounds than the old Cherokee. The newer, more boxy Liberty may be lighter. It is much quieter and more car-like on the road with independent front and rear axles, but no zerk fittings. Typical on highway mileage is 22-24 for the Cherokee and 20-22+ for the Liberty. My son's 2002 Liberty gets same highway mileage.
I replaced the PCV valve before I began the Auto-Rx procedure. I have not ruled out PCV plumbing issues or rich fuel mix difficulties, but at least the check engine light is not winking at me.
These Jeeps get a full workout during the winters up here. A man hasn't really lived until he digs out his wife's car (formerly an excellent 1992 Mercury Grand Marquis, but 2WD) from the commuter parking lot after the municipal snowplow leaves a modest 12 inch mess behind. Of course that is not a problem for either Jeep.
Thanks!
Hmmmm ... I'll only comment that my wife's 2002 Liberty with the same engine does not use any oil. We bought it new, and even when I was doing yearly changes (early on) using Amsoil 5w30, with a filter change & top off at 6 months, the car still did not use oil. I've since changed my habits to oil/filter change at six months .... but still no usage.
The ARX is a good idea. I ran one treatment around 40K just as preventative maintenance. The car now has 67K on it.
I will also comment that on early Liberty's - like ours - there was a TSB out for revised PCV routing. I am not sure what years the TSB referred to - but it did on our first year Liberty. One sure way to tell - if the oil fill spout has a pcv valve there - that is the issue they revised. The revision kit replaced the oil fill spout with a non-vented one, and added a PCV valve & hose to the rear of the driver's side engine. I bought the kit for $40 or so from Chrysler & did it myself.
Good luck on your ARX application.
I'll go over to the Jeep dealer next week to find out more about the PCV technical service bulletin. The oil fill spout on my 2006 has the PCV valve attached to the spout. The spout also has what appears to be a removeable baffle to keep oil bottle caps from falling in.
Thanks!
Several other Auto-Rx threads also mentioned benefits of extending the cleaning phase. 3000k miles for cleaning phase is probably enough. There is always the possibility of a second clean/rinse cycle
Thanks!
got an 06 3.7L (40,000 miles)in the family and it uses no oil (5w30) between changes. is it possible the previous owner didn't maintain it?
auto rx sounds like the answer.
Yup, I believe it likely that the previous owner did not maintain it faithfully. If that wan't the case, short idling and cold to and fro movement on the dealer's lot could not have done it any good (per a Wall Street Journal front page piece about a year or so ago...sorry I don't have the article on hand.)
I thought I was OK with the original factory warranty because I bought it from the dealershilp where our family bought several other Jeeps. There was more than a year and over 10K warranty miles left, so if something obviously failed, I'd be covered. Perhaps there is a lesson in this?
Auto-Rx won't turn back the clock, but if it does half of what other folks have posted, I'll be very happy.
Thanks!
Six in a row-
Don't be surprised if the dealer gives you the "deer-in-the-headlights" look, so here's some info to go armed with:
The TSB number is 25-001-08. It is dated 1/8/08, and entitled Emissions-PCV system freezes in extreme cold.
If you want a hard copy, PM me a fax number, and I would gladly fax the TSB to you.
Steve
Market525-
Market525 said:
Six in a row-
quote]
I got the combination of "deer in the headlights" and "can we do this after the holiday?"
Thanks for the ammo!!! I will post the results of all of this.
BTW, the Auto-Rx is three hundred miles under way..
ARX is definately your best bet. I've used it for 3-4 years now on different cars. Plan to do back-to-back treatments, if you haven't already done so.
I'm betting you are going to see positive results!
Steve
