Originally Posted By: roadrunner1
Well I thought I would add to an old thread vs. starting a new one
'07 6.0 powerstroke
sampled on 9/4/11
John Deere Plus 50 10w30 CI-4
7,483 mi. on sample (134,859 mi. total on truck)
iron...............................11
chromium............................1
nickel..............................1
aluminum............................1
lead................................2
copper..............................2
tin.................................2
silver............................ titanium........................... silicon.............................7
boron.............................203
sodium..............................7
potassium......................... molybdenum........................139
phosphorus.......................1505
zinc.............................1769
calcium..........................4388
barium............................ magnesium..........................15
antimony.......................... vanadium........................... fuel% vol.......................... t/s% vol............................1
water% vol........................ vis cs 100c......................10.5
This was my last of the CI-4, current fill is CJ-4 Plus 50 II. Every sample of this brand/grade has been almost exactly the same as the previous one
Hot off of the printing press I have the latest UOA for this truck;
John Deere Plus 50 II 10w30 CJ-4
sample drawn 1/10/12
OILSCAN (through Deere)
7,300 miles on sample
142,158 miles total
'07 F350 6.0 Powerstroke
iron.....................................16
chromium..................................1
nickel................................... aluminum..................................2
lead......................................4
copper....................................1
tin.......................................3
silver.................................. titanium................................. silicon...................................5
boron...................................275
sodium....................................5
potassium............................... molybdenum..............................256
phosphorus.............................1172
zinc...................................1367
calcium................................2242
barium.................................. magnesium...............................726
antimony................................ vanadium................................. fuel% vol............................... t/s% vol..................................1
water% vol.............................. vis cs 100`C...........................10.4
This was my first run of the CJ-4 spec lube, it appears the only real differences are the added magnesium, boron, and moly. Then decreases in phosphorus, zinc, and calcium, typical for CJ-4 speced lube.
Wear wise there doesn't seem to be hardly any real differences between this report and the last 7 or 8 reports, FE went from 11 to 16 and I really don't see that as an issue.
