Jb weld creation: ratchet drive drain plug
California
What do y’all think… is it brilliant? Crazy? I jbwelded the socket onto the drain plug so I can just put the square part of the ratchet in there. Plus it will make the last part of unscrewing it by hand easy and less messy.
Time to patent that creation. Fumoto and likes should be concerned.
Joking aside, good idea. I would make an engine oil drain plug with square built in. Something like Honda/Acura does with their transmission drain plugs.
On most of my vehicles the drain plug sits reasonably low and I wouldn't trust a JB-welded socket to adhere to it long term especially exposed to debris, flying objects, water, salt, etc... Personally, I'd just go with a new drain bolt of the appropriate thread size/pitch with whatever head size or square drive I desired. My fear would be that the socket will be long gone in a few months (due to applying to two shiny surfaces) leaving a messy hex head with JB weld slathered all over it that a socket won't attach to.
Keep us updated if it works though!
Not bad. Likely not done a lot due to possible weakening of the bolt head & maybe prone to break easy.
We all joke n rib one another. Joking aside. I was told not long ago that a fellow I went to high school with invented some simple small accessory tool for holding welding rods and is today in the millions and was then elected Mayor of the small town he was doing construction / welding work in. Diamondville, Wyoming....way up there in the wide open spaces. From welding out in the cold prairie to fat bank account and pushed into politics almost over night.
I would maybe had used the original gray J B weld for a little more security but party on. If Ford can use those plastic pan plugs with the recessed heads, who's to say.
