I have a 1995 Jaguar XJR engine (supercharged 6 cylinder) and transmission that I am in the process of transplanting to another vehicle. When I bought the car, the PO had broken the boots to the traction control cable so the throttle cable was binding randomly, causing idle speeds in park anywhere from 750 to 1800 rpm. Needless to say, it went into gear with quite a thump with the engine running so fast. After seeing some of the videos from Precision Tarnsmission, I'm wondering what the conditions of my clutches are. It shifts and drives as it should, but I have a nagging suspicion that it will need a rebuild sooner than later.
If I do rebuild it, what are the differences between the Jaguar version of the 4L80 and the Chevy version? So far I know the case, extension housing, output shaft, pan gasket, torque converter and wiring connector are different, are any of the internal parts different/beefed up to handle the power and torque of the V12 and Supercharged 6?
If a standard centre lube GM rebuild kit will do the trick that would make life easy, or suggestions of any other things that should be changed to offer longevity would appreciated. It's going in a limousine, so I'm not towing or doing 1/4 mile runs, but it is a heavy car (6000 lbs) and I will be driving it through long, steep mountain grades, so it will be working hard. I've done a few mods to the engine, so it's making a bit more power than factory about 350hp and 450 ft-lbs (factory was 322hp, 378 ft-lbs).
