Originally Posted By: Vikas
Originally Posted By: Trav
Cut a hockey puck to the required depth.
I did but without the proper tools, the procedure is a nightmare!
Originally Posted By: JHZR2
What is the right depth? To allow the pinch weld to bottom out and some mass transfer to the surrounding area, or just enough to keep the weld in place when jacking it up?
Thats why i think a piece of square wood is better you can run it through the table saw. I'd just measure the pinch weld and add 1/4 or so for the wood to compress. Dry oak should not compress much but softer wood might. I'd make the slot across the grain , to avoid splitting.
Or screw the hocky puck to a square piece of wood temporarily and use that to run against the rip fence. Just be aware of how you orient the screws so they don't hit the blade.
