So I’m trying to flesh out some ideas for understanding but don’t know if any of our experts can go “on the record” with the information, but wanted to ask:
There are plenty of people here concerned about IVDs in GDI/GTDI engines, and it’s assumed by many here that the prime generator of these deposits are via the PCV by sucking oil into the intake without any gas wash to clean them. But it appears from my personal testing that a good portion of the additives in the oil stay in the pan, and a majority of PCV vapors are base oil alone even though there are some additives carried with the oil.
Since we’ve learned that ANs & POEs are very good at cleaning, in the ring lands as well, and clean, happy compression & oil pack rings should help keep all the combustion byproducts out of the oil itself, is there any data which shows if ANs & POEs will: 1. Volatilize and be carried with other vapors into the PCV tract, and 2. Clean surfaces or at least prevent deposits on surfaces the vaporized chemicals come in contact with?
Gist of the point- we know thanks to the experts that while in the pan everything gets cleaned by the AN/ester combo. But when these are sucked through the PCV into the engine, are they cleaning the intake valves on the way past, and are they cleaning anything in the combustion chamber (similar to PEAs)?
This would give those who are concerned about IVDs a way to minimize their risk via spending a little more money on the front side thru buying oils with ANs & Esters in them. Just a thought; I know this may be treading into proprietary info so I’m not sure if we’ll get much professional info here. But here’s to hoping the answer’s YES!
