The dreaded Mazda specific CEL code P1195 for MAP Booster Sensor malfunction for the '98 Protege with 218k. Usually caused by carbon blocking the port from the intake manifold to the sensor. Recommended fix is a manual cleaning of the port located just past the throttle body (est $400) and/or a new sensor ($600
) Basic driveability issue was uneven/stumbling idle particularly with the A/C on at idle. So, instead I threw everything including the BITOG kitchen sink at this little Z5 1.5L engine over the past 18 months the CEL has been on. ARX (x2), LC20, FP60, Molabrew, Techron, Amsoil Power Foam, Neutra 131 (gas and crank), MMO, and Lucas UCL all per instructions. Not all at once.
Sorry, no ATF. The light first flickered off during the ARX treatment and then became more intermittent recently with regular Molabrew at about 2 oz's per 5 gallons of gas. This all took place over about 15k. Oil was Rotella 10w30 or Havoline 10w30 at 4k OCI's and decent filters. Over the past few days the CEL has stayed off. It flickers at start up so I know the bulb has not burned out and the idle is smooth at 750 rpms with or without the A/C on. I suppose it was a combination of direct application of the CC cleaners and probable oil blow by with ARX, LC, N131, etc mixed in to the intake manifold which finally unblocked the clogged port. I like it! Thanks BITOG.
