- Joined
- Dec 20, 2024
- Messages
- 1,602
In one mile driving ?...Pilot is warmed enough by then...
1 mile is normally enough to let it kick in. If it doesn't see enough parameters warm enough it will still rev to higher rpm but not have the VTEC kick in. Sound doesn't change, no "boost" feeling. Next stop light about a mile form that then works fine. Depends if I'm by myself or with others if I do that.In one mile driving ?
Ya. Apparently there are a couple of SAE papers surrounding aspects of it and it just doesn't appear to work.I run Top Tier all the time. I mean, it's a Corolla, so I'm pretty certain with even moderately poor maintenance the engine will last 300K miles. But yeah, probably better but less fun.
And Valvoline Restore and Protect, Mobil 1 ESP 0W-30 and maybe a couple others.Aside from routine maintenance, a bottle of Redline Si-1 once a year, and a good highway run (1 - 2 hours) occasionally is all your Corolla needs to keep the engine running at its' best.
I don’t think any TB snaps rapidly closed anymore especially in manual transmission cars. It is an emissions thing. That instant throttle closure makes a puff of something noxiousPretty sure an important part of the tune up is not just the WOT to bring up temps and get things cooking but then to SNAP off the throttle so the TB plate closes completely creating high vacuum to really suck the crud out.
That's my usual commute. 16 miles of highway in under 12 minutes.I cruise at 90 MPH and hit 100 regularly on the highway.
Helps to keep everything get up to operating temperature and running smoothly.
2x and its gets the cats hot enough to burn off around town putting around build ups. Had a daily commute up a long pull hill and I could tell who in front of me just did short around town driving by what was coming out the tailpipe via sight and smell.Others said it well, it's not just the RPM, but also the load. Gunning up a mountain is the best ITU there is. Ok, maybe doing it in the rain with no air filter might be slightly better.
Opinions are going to vary heavily. One recent example, I ran into a purchase of used msf course motorcycles. All parking lot miles. After driving and beating the living snot out of them on the open road, within 1,000 miles of what I call "Italian Tuneup" loosened them up, and regained their power. It most likely was a combination of improved ring seal, valve seat, and overall carbon reduction.Interested in opinions and thoughts from the all of you, knowing they'll be all over the map.
2017 Corolla has "D" for drive and "S" for sport mode. As an aside, "S"-mode is scary given the outright power Corolla's have under their hood. When in "S", it's hard not to chirp the tires when lightly feathering the throttle when a red light changes to green.
Anyway, back to the actual question: Is there a benefit to driving in "S" on, say, a 45 mile highway trip to keep RPM's around 3K instead of under 2K? You know, the old "Italian Tuneup" or "Blow the carbon out" type of thinking?
Opinions (based on fact or fiction) in 3-2-1...
I do an italian tune up a couple times a month mostly to blow out the carbon on ym DI engine, otherwise mostly operated in a extreme short trip regimen.Interested in opinions and thoughts from the all of you, knowing they'll be all over the map.
