It will be a nightmare every time I change oil
Yes its that easy, practically a one handed endeavor.
A couple of things I do differently....
1. I do the filter first on my Audi. When I unscrew the filter housing mine is hand tight when properly torqued and aligns with the factory paint pin mark every time so I dont even get the torque wrenches out any more.
2.I get my first beer. Once the seal is cracked on the filter housing I can hear a slight gurgling of oil back into the engine (drain back valve?) so this gets more oil back into the sump. Additionally there is a couple tablespoons of oil that can be sucked out of the base of the housing and as soon as it is clear I stick the suction tube into the dipstick tube. The Audi has no dipstick though just a cap.
3. While the sump is being drained I do the filter and o ring change.
4. Once I'm done with the filter I let the sump drain until it starts sucking air. And get beer number two ready.
5. Once beer two is completed I repump the extractor and move the tube around a bit to clear the additional oil that has drained during the second beer.
6. Once the sump is empty I replace the dipstick tube cap and start adding oil. I put about half a litre carefully into the filter housing to possibly get some oil into the lines coming to the filter and reinstall the filter housing and align the marks which is a firm hand tight. I dont think it probably makes any difference but it makes me feel better. I then put the remaining 5 litres into the sump and get on with life.
The only messy part of the whole operation is changing the O ring on the filter housing.
Every oil change for me is a one handed endeavor, since I only have one arm.🤣
Very informative, Sir. The oil filter in the Jag is a non-canister paper filter. Do you primed it with fresh oil before you put it in the canister? On my other vehicles with canister oil filter, I primed it with fresh oil, let it sit over night and then add additional oil before installation.
Yeah I dont preoil the filter i just pour some down the base of the filter housing into the engine. I have no idea if it does anything. The filter is a paper cartridge also.
