Originally Posted By: rudolphna
Trust me, we just did an entire unit in chemistry about oxidation numbers and bonding. Only non-metals can bond molecularly (covalent), when you bond a metal and non-metal (metals cannot bond) you get ionic bond. I will see if I can find a link, but for now I ask that you take my word for it. I have nothing to gain by making it up and did not post this to cause trouble. Simply that they named it wrong. Molybdenum is a metal. Sulfur is a non-metal. When they bond, it's an ionic bond. Ionic bonds do not get prefixes, they get roman numerals for the oxidation number of the metal.
This is the best I can find for now. I'll try to scan the stuff we've done.
http://www.angelo.edu/faculty/kboudrea/general/formulas_nomenclature/Formulas_Nomenclature.htm
LOL
I wish chemistry were as simple and clean-cut as you picture it here.
It's not.
Molybdenum is a metal, yes. But it's a transitional metal, and that's what makes a difference. Transitional metals tend to have extra electrons sitting parked in weird orbitals, and these electrons can be convinced, rather easily, to share themselves with other atoms that happen to be nearby, sometimes of an opposite chemical orientation that the metal in question... in other words, bonds made by transitional metals are not as clean-cut ionic that the ones made by say alkaline metals. They are prone to making (Oh the shock! The shame!) covalent bonds.
Also, some non-metals that have a less non-metallic character than other, more electronegative non-metals, are known to be easier approachable by transitional metals to form (The shock! The shame!!) covalent bonds with them. Case in point: carbon, and all the organometallic compounds. Or maybe that's the next chemistry module you'll be taking.
To drive the point home: I wouldn't be so quick to say "MoS2 is definitely an ionic compound, and it should thus be named such and such" without bringing some evidence. In fact if you run a quick search, there is strong evidence to suggest that the Mo-S bond is part ionic, part covalent.
(edit) BTW, you say, quote "The oxidation numbers of Sulfur are -2, +2, +4, and +6"
Have you given any thought on how can sulfur, a non-metal, have positive oxidation states? What do these exactly mean?
--jhenle, PhD
