Originally Posted by Mad_Hatter
Originally Posted by SR5
I've posted this before recently, but it does support what the OP is saying.
Here is the owners manual from Australia for a 2018 Camry Hybrid, it says you can use 0W16, 0W20, 5W20, 5W30, 10W30 or 15W40
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4890579/1
For 15W40 Toyota say to use API SL or SM or SN.
Can't call that too fussy, 0w16 to 15W40, SL to SN, in a modern car, in the factory owners manual.
Just make sure you have the correct cold starting ability for your climate, and the oil is changed at reasonable intervals. Job done.
Yeah, I've seen that thread. My guess is the engine builders wrote that section of the owners manual and it made it out the door before the marketing dept or in house CAFE expert could proof it....‚
US CAFE requirements. Not Australia.
Toyota did the same thing with the 1GR-FE (v6 Tacoma, tundra, hilux, landcruiser, etc.).
In Australia they recommend 5w30 below 60F. 10w30 above 0F, 15w40 above 10F, and 20w50!! Above 30F.
In the US? 5w30 in all temps.
CAFE requires the grade used in testing to be the grade in the manual and on the fuel cap. Manufacturers in the US are absolutely beholden to CAFE.
Outside of warranty I look to the global market recommendations and base my oil grade choice on the temperature charts provided there.
