Is Walmart EverStart as good as Sears DieHard
It is as good as the DieHard and for less money. I have had several Everstarts over the years and have found that when I have had to return them that Walmart did so without any problem.
However, when I had to return a 18 month old DieHard gold with a bad cell, it was a great deal of hassle and it cost me $41 to walk away with a DieHard Silver.
FYI there is a reason they spec changing brake fluid every 2 years.
It has nothing to do with how much you use the brakes. It is all about time. Brake fluid is Hygroscopic so it absorbs moisture in the air and that will eat away at the lines & caliper pistons eventually as it is trapped.
This goes double if you have ABS/EBD/ESP...
