Is this old reel mower i have worth anything?
NY
Old reel mower with a brigs and stratton engine. It appears all there. Thought it was interesting oil spec is 20wt or 10wt.
If it's in good working order, I wouldn't mind having it to mow a practice putting green. You could easily sell it to a golfer with a decent sized lawn.
I presume it works. I got it as a project to clean up and get working nice but it’s been sitting in my garage for 10 years and I’m unsure if i should keep or sell
I love the idea of seeing it running but would not personally commit space. Probably needs points from sitting.
You are gonna get a lot of I would love to fix it up but don’t have the time.
Put it on a market place for a price that would make you happy. The longer it is in your way the less you will take for it.
Yes i believe its that old
It is way older than that. The B&S 5S was produced from 1949-1957, the six digit serial number indicates that it is very early production, 1949 or maybe early 1950. The engine was only rated at 1hp, but reel mowers didn't need as much hp as rotary mowers because they cut much more efficiently.
The mower itself looks like an Eclipse.
Whether or not the mower can be made to work and cut properly will depend on the condition of the reel's bed knife.
Yes, definitely. If it's in bad shape you can send it to a professional shop. A machine called a "bed knife grinder" is used to restore it. The process is similar to sharpening the blade on a commercial paper cutter.
If the bed knife is in good shape, you can sharpen the blades by putting lapping compound on them and turning the reel backwards with a hand crank. You can buy an inexpensive kit for this.
What oil should i run in this thing? Im sure whatever’s in it is wrong and old as dirt.
10w30 should be fine. Any modern oil is light years better than what it was born with.
Brings back memories of my introduction to mowing. Reel mower with a Clinton motor. Wind on the piece of clothesline rope with the wooden toggle handle to start it.
What I meant by condition was... is it straight. Since reel mowers are designed to cut specific types of grass VERY short (down to 1/4"), the bed knife can be bent by hitting something solid, like a rock. Once the bed knife is bent it will need to be replaced. These used to be easy to obtain and easy to do back in the day, which is not going to be the case on the old one that the OP has.
Nice! I've got a very similar reel mower made by Savage arms. Its a 53 or 54, with the same Briggs on it. I use 10w30 hdeo in mine. I don't use it often anymore, but it will still start by the 3rd pull. I paid 100 bucks for mine when my wife and I bought our 1st house. It was my regular mower for nearly 10 years, now I try and use it for mowing a couple times each summer. I really liked how little gas it used.
