Is this concentrated or already 50/50?
IN
Looking to fill my 2011 focus and I found this sealed jug in my garage. It’s old! lol
The back label is gone but the front label remains. My stupid question is…. Is this a 50/50 mic or is it concentrate and needs to be mixed?
Any help would be appreciated.
Thanks in advance
Ugh - Its not really clear is it. Most bottles have say on both from and rear if its a 50/50 mix, and looking at the opaque green, it appears to be straight coolant with no water, but no way to be certain. Especially from where I sit. Safe bet is to recycle it. Sorry.
It looks like concentrate to me, but why don't you mix a cup of it 50/50% with distilled water and check the freeze-protection level with an anti-freeze tester?
attached is what I think might be the back of your jug.
It came from here:
https://offerup.com/item/detail/16e4acac-c2cc-3366-a36f-59cf915c6cd5
Even the back label is horrible with respect to determining what you have.
But I think it's concentrate because just below that table it says "50% solution recommended. Do not exceed 70% concentration of antifreeze"
This seems to imply that the jug you have is concentrate.
Also the directions read (3rd bullet) "... Fill with enough new coolant to achieve a 50/50 antifreeze/water ratio."
but wow..
Just putting "Concentrate formula: must be diluted with water. See table below" sure would have been a lot clearer.
What I see from the label, it's concentrate AF. Needs to be mixed with distilled. I don't go by color depth. If it's a premix, worst job ever of identifying as such. As noted, can always test with an inexpensive tester like a 5 ball AF tester.
