A local guy has a 2008 Scion xD (1.8L 2ar-fe engine) with 201k miles for sale. It starts and idles fine but dies whenever you put it in D or R, but not N. He’s thrown a ton of parts at it to try and cure a misfire code in one cylinder with no luck. He also said his mechanic told him the compression was low on at least one cylinder. I pulled the oil cap off while it was running and there was quite a bit of blowback, making me wonder if the rings aren’t gummed up. If so, this might be a possible candidate for rejuvenation with a piston soak.
He’s asking $1200. I would probably offer $800 and maybe settle on $1000. I figure it’s worth a few hundred to the scrapyard if my gamble doesn’t pay off. Or I could maybe use it as a learning tool to remove and try to rebuild the engine. The body and underside are remarkably good for a 2008 car because it spent most of its time in Georgia.
Would you take the gamble for $1k?
