I have a Be Cool Radiator with the internal trans cooler in the radiator, the radiator is about 10 years old and has a slight leak at the top of the radiator where the cooling tubes and tank meet. A new 1 is $650.00, expensive, I know they do not make there own radiators. I wanted to either get the Be Cool universal radiator for $200.00 with no internal trans cooler or the Summit 1 for $180.00 and it has no internal trans cooler. I can get a B&M external trans cooler for $50.00. My transmission now which is a Turbo 350 has a Derale trans pan with cooling tubes, it has been Auto-Rxed and is using Amsoil ATF, when I take a reading of my torque converter with the infrared gun it reads about 160 degrees on a cool night and about 170-175 degrees on a hot day, the pan reads about 100 degrees but this is where the cooling tubes are, a little bit up on the pan and it is about 155 degrees. I think my Be Cool radiator must have an excellent built in trans cooler but cost wise I think it would be better running just an external trans cooler, it would be less stress on the radiator and the B&M unit has a bypass that when the transmission fluid is cold the fluid bypasses the cooler. So my way would be about $250.00, another BeCool radiator would be $650.00 with the built in trans cooler. So what does everyone think.
