‘Defect’ Can Cause 2013-2018 Nissan Altima Headlights to Get Dimmer Over Time, Class Action Says
Link to story:And here's a video that discusses the same problem.
The reflective surface inside can degrade over time which would render the headlamp pretty useless. It appears that manufacturers spare every expense and lay down some shiny aluminum just a few microns thick. And all the car-makers are buying parts from the same suppliers, so I don't think the problem is unique to just one company.
There doesn't appear to be an easy way to just change out the elliptical reflector inside the projector housings in most vehicles. You need to change out the entire assembly which is $$$$$.
There's not even an easy way to check the condition of the inside surface either.
