Carlostrece
$100 Site Donor 2025
My LG front load washer wore out its drum suspension system. It needs 2 new springs and 3 new shocks. I ordered the parts. My cousin will install by following instructions in a couple of Youtube DIY fixit videos.
Each shock is held in place by a white plastic mounting pin that goes through a hole in each end of the shock. The instructions in one video say to grease the new mounting pins before installing them. The guy use a small brush to slather on some of clear lubricant that he referred to as grease. Is there a type kind of grease that is compatible with plastic (or nylon)?
I'm wondering if the pins might be nylon, even though he referred to them as plastic.
In another repair video, an older repairman replaced the same 3 shocks. He used liquid hand soap to lubricate the pins.
Prior to watching these videos, I would have used NAPA Mac silicon spray lube because I know it's plastic, nylon, and rubber safe. However, I also know silicon spray lube won't last as long as a grease would.
The shocks mounts will rotate/move soms on the pins. It'd be nice to lubricate them with something that is plastic/nylon safe and lasts as long as possible before drying out or wearing out.
What do you recommend?
