Originally Posted By: edhackett
Actually it's closer to 1/4 of a dime.
PPM= mg/L
5L x 100 ppm = 500 mg =0.5g
A dime weighs 2.2g
0.5g/2.2g=0.227
Ed
Good example, to me 100 ppm of iron is a lot of wear then, especially to someone who really cherishes their vehicle and wants to keep them a long time.
Now we go full circle and ask, is the iron really from wear, or some chemical reaction that shows Fe in an analysis? Once again the only true way to accurately measure engine wear is the very impractical tear down. Or just take the analysis results with a grain of salt, and look for dirt injestion, anti-freeze, excess fuel, and bearing wear, then call it a day.
Now you can imagine why I become concerned with a 4.2L V8 that has an 8200 rpm redline with an Aluminum block and Al/Si cylinder walls shows up with 30+ ppm of Fe, in an engine that is broken in, after 6000 miles on the oil, considering that the engine has a 10L oil capacity. This is equivalent to an engine with 3L oil capacity having 100 ppm of Fe in a UOA. No matter how you look at it, that's a large amount of Fe in an engine that has glass cylinder walls.
PPM= mg/L
A dime weighs 2.2g
0.5g/2.2g=0.227
Ed
