Originally Posted By: Newtonville
Some questions/comments:
What about oil pump parts, valve stems, tappets, drain plug threads, drain hole threads, oil cap metal tabs, dipstick tube and dipstick, chains, and a number of others I probably can't think of? These could be sources of Fe as well as cam lobes. Also the test accuracy error. Is it meaningful to love a used oil with 10ppm Fe results, and hate one with 16ppm? Is 100ppm Fe anything? What is the definition of ppm, and ppm Fe in oil analysis? Just wondering, don't know anything.
These are excellent and relevant points. Don't feel like because you are new to the discussion that you don't have any good ideas. Sometimes (often in fact) a fresh view of the situation can reveal some obvious flaws that those on the inside don't notice.
I wonder also, even assuming there was some validity to the test for Fe and engine wear (which I not willing to admit), whether such tests are conducted properly. For example, to be accurate, the same engine or identical engines would have to be tested. If the same engine was tested back-to-back with different oils, how much residual Fe is there at the bottom of the oil pan that could get incorporated into the new oil put into the crankcase. And as already noted, some oils do a better job of suspending particulates than other oils.
The number of variables here is astronomical. But bottom line is that if you want to evaluate a motor oil for how much engine wear occurs when using it, look at the engine. That my be inconvenient (or impossible) for the average person, but that doesn't make using a inferior method of analysis for engine wear any less invalid.
