Hi Guys,
I know this may seem like a stupid question, but you will understand my logic by the end of this post.
So Its time to flush the trans in my '03 Windstar again.
and I have no Mercon V fluid. (And have no money as I'v been out of work since Febuary) BUT my dad has ALOT of T-IV (Toyota Bottles) Like 50-75 Quarts. He works at the dealer, and when you have a little left over, he uses the open quarts instead of opening another bottle on the next job. He has collected this much fluid over the last 2 years. I have seen at Wal-Mart, that the Dex VI is compatible with T-IV, and Mercon V. So is Mobil 1 ATF.
I know that the T-IV is made by XOM, & I have a suspicion that it maybe Mobil 1 ATF just rebottled. (Can anyone confirm this ?)
My question to you is this, Is the T-IV compatible with
Mercon V, and if so can I use it in my Windstar ?
It has the AX4N transmission.
I plan to drop the pan, change the filter, refil, then flush the transmission at the dealer my dad works at with 16 quarts of atf.
Thanks Guys,
Justin
Thanks Guys,
Justin
