Motor oil rookie
Thread starter
- Joined
- May 3, 2025
- Messages
- 206
I want to learn.How long are you going keep this going?
Is that it.I want to learn.
Yeah. I have learned so much so far.Is that it.
You could’ve fooled me.Yeah. I have learned so much so far.
The Pentastar is port injected, so fuel dilution isn't an issue. It has a reasonably large sump and good thermal controls, so, despite having a fair amount of timing chain, it's reasonably easy on oil (as evidenced by the 626,000 mile Pentastar example).I see. They say my Pentastar is very easy on oil. So it cannot do that. So I'm good with HPL Supercar 0W-20.
Can one buy a shearing machine?
Give me example of an engine that shears the @@@@ out of the oil. Supercharged Hemi?The Pentastar is port injected, so fuel dilution isn't an issue. It has a reasonably large sump and good thermal controls, so, despite having a fair amount of timing chain, it's reasonably easy on oil (as evidenced by the 626,000 mile Pentastar example).
Engines with a lot of chains, turbo and DI. A pushrod V8 won’t tax an oil that much.Give me example of an engine that shears the @@@@ out of the oil. Supercharged Hemi?
Ah c'mon - we put up with that one guy with the Taurus that kept on asking us if we wanted him to post pictures of his dipstick for MONTHS.You could’ve fooled me.
Easy. He hasn't even gotten to Death Valley yet.How long are you going keep this going?
Hey, I just received report of my Red Line. They say oxidation value is very high, so it must contain truck loads of Ester. Can't wait for November when I do used oil analysis.The Pentastar is port injected, so fuel dilution isn't an issue. It has a reasonably large sump and good thermal controls, so, despite having a fair amount of timing chain, it's reasonably easy on oil (as evidenced by the 626,000 mile Pentastar example).
Yes, Redline always shows high virgin oxidation due to the ester content.Hey, I just received report of my Red Line. They say oxidation value is very high, so it must contain truck loads of Ester. Can't wait for November when I do used oil analysis.
What advantage does high oxidation give Red Line against oils like Mobil 1 Extended Performance?Yes, Redline always shows high virgin oxidation due to the ester content.
None. Esters raise the base oxidation as measured via oil analysis, certain esters raise it more than others. The one(s) Redline use seem to push the number up a fair bit.What advantage does high oxidation give Red Line against oils like Mobil 1 Extended Performance?
Esters have carbon-oxygen double bonds (C=O) that are interpreted by the ASTM test as oxidation (which it is, but not what is "bad" in motor oil). It is more or less an artifact of the test. Some esters have more of these bonds, perhaps Red Line uses a particular ester that has a high number of them. Both quantity and type will affect the observed value.None. Esters raise the base oxidation as measured via oil analysis, certain esters raise it more than others. The one(s) Redline use seem to push the number up a fair bit.
I couldn't find a date code. Does the batch# say anything? 24L2004None. Esters raise the base oxidation as measured via oil analysis, certain esters raise it more than others. The one(s) Redline use seem to push the number up a fair bit.
My catch can testing on HPL PCEO 5w30 showed surprising results; even surprising @High Performance Lubricants as not only the lighter ends of the oil ended up in the can, but also a measurable amount of the add pack. High Noack is an insidious, hidden killer of oils. The more the oil evaporates, the more add pack it carries with it. A max-Noack oil will leave your engine with… Lucas oil stabilizer. The heavier ends with no additives left!Viscosity loss is most rapid early on, then tapers off. That viscosity loss from shearing happens at a faster rate than oxidation. Eventually oxidation will slowly start raising the viscosity, but most people don’t run oils long enough for the viscosity to equal the virgin viscosity. If the oil is run extremely long so the remaining active antioxidants drop to a critical concentration, viscosity increase from oxidation rapidly rises. Outside of testing, the only people that run oils that long (likely >20k miles) are the utterly neglectful types who quickly ruin their engines.
Oils without viscosity index improvers experience negligible viscosity loss from shearing. Only the dispersants are prone to small amounts of permanent shearing.
Would have to ask @High Performance Lubricants whether the batch code corresponds to a date.I couldn't find a date code. Does the batch# say anything? 24L2004
View attachment 279285View attachment 279286View attachment 279287
Will shoot Mary an email.Would have to ask @High Performance Lubricants whether the batch code corresponds to a date.
