Is RTV Silicone corrosive to painted metal?
Bayonne NJ
Recently my 2017 VW GTI started leaking through the rear speaker, apparently it is a problem with the MK7 platforms due to the seal behind the speaker deteriorating over time. It is a CPO but I rather just fix it myself than take it to the dealer.
Basically the speaker has a rubber/foam gasket that forms a seal with the door. I wanted to know if I could use any RTV silicone sealant or would that be corrosive to the metal over time? I heard some sealants are acidic and could eat at the painted galvanized steel.
Yes most RTV sold most places is an acetic acid cure. You can find alcohol cure RTV however, those are sometimes labeled as potting compounds. I bought Dow Corning 838(?) once from McMaster-Carr to seal up a trailer wiring connection.
Once the RTV has cured though you should be okay.
How about Permatex Ultra Blue?
I've looked the TDS report on Permatex's website and it doesn't list Acetic, also states that it's non-corrosive. Should I just go with a neutral silicone instead?
The corrosion issues are with yellow metals, solder, zinc and galvanized steel. There are neutral cure silicones that do not release corrosive acetic acid, for example, Dow Corning 737. It's heat-resistant to 350F.
I once used some Gorilla brand clear silicone on a female friends gasket of the 3rd brake light. I didn't go crazy with it. I just applied a dab and smeared it on the gasket. A few months later I noticed 1 of the bulbs wasn't working. When I removed the light the paint came off with it in a few spots. 🤷‍♂️
