From the other thread:
". However, since the refineries are being forced by the government to remove the contaminants in the fuels (sulfurs, heavy metal, etc.), the newer oils do not require the amount of TBN that they did say 5 years ago. Running an oil that is “over based” with higher levels of TBN than required could result in increased valve deposits and ring deposits."
I thought this was a result of GF3 and SL compliance instead of fuel related in the lower TBN ? Leaking injectors,short trips are still a problem no matter how good or bad the gas is
About Royal Purple. I have not seen a analysis with the oil used in a engine that was not near brutal on a oil. I think it is probably a very good oil and would be interested in seeing a result from it used in a motor that did not tend to shred a oil like a paper shreader on Capitol Hill.
Prior to the coming of this board I spoke with a Royal Purple Rep on two different occasions about a needed lubricant,he was very friendly and almost was a open page as far as info on the products we spoke about,,much friendlier and helpfull than some others I have done business with,or rather will not do business with again as in buying and using their oils
![[Mad]](images/icons/mad.gif)
You know,this is off topic as can be but I believe many expect too much out of these oils available to us. Good wear control and whatever drain interval per application/use to keep the engine in top shape is where it's at for me.Running a oil until it is near dead then changing and pouring new oil only to be contaminated by the old does not make sense to me
