- Joined
- May 30, 2025
- Messages
- 3
Hi all,
So my wife has a 2020 Kona which has the bluish green Hyundai coolant. She hit 120k miles so I went to change the coolant as per the manual by doing a double drain and fill. I used supertech blue for the first drain and fill and then Prestone blue for the second. I would've done both with supertech but they only had one left of both the supertech and Prestone. Hindsight, I should've just gone and gotten 2 bottles of zerex Asian blue at that point but here we are. I figured since they cover basically the same brands except for Hyundai according to the bottle, and are both POAT then it'd be fine to use the Prestone even though it doesn't specify Hyundai specifically. My only concern now is if the Prestone has anything that would not be good for the cooling system, namely silicates or borates. The reason why I'm worried is because the Prestone green color specifies on certain websites that it's silicate and borate free but not for the blue. But logically speaking, if it's rated for vehicles like Honda and Subaru, then it should be silicate and borate free, right? I'm probably overthinking it and it's fine, but we're about to go on a long trip and if I need to flush this system out and just go get OEM fluid then I'll do it ASAP. Any help is super appreciated.
