If the rotors are good, no noise, no pulsation I do a pad slap. So far no problems to report.
Sorta. There’s still people doing it, but it’s not typically cost effective. If you pay someone, it’s usually not much more to get a cheap set of rotors and be done with it, just parts swapping.is turning rotors and drums still a thing? i used to do that, but haven’t worn out a set of brakes in ages.
thanks!Sorta. There’s still people doing it, but it’s not typically cost effective. If you pay someone, it’s usually not much more to get a cheap set of rotors and be done with it, just parts swapping.
Around here the rotors are likely heavily rusted anyhow, lots of grooving.
Revenue. Much more of it when you suggest replacing the rotors, maybe calipers, brake hoses and a brake fluid change instead of just replacing the part that actually wore out.So why is pad slapping considered bad in the pro mech industry?
That is not a pad slap. If you clean the rust on the brackets and lube the pins and replace or clean and lube the spacers and shims in the working areas - that is a brake job. Just to give a surface to bed to I also file off the lip at the top of the rotor and take a grinding wheel on my drill and rough up the rotor surface a bit with a ziz-zag pattern across the face.i recently help a couple of my sons friends do brakes on their vehicles. one was a 2018 Volvo S90 T6 with 28k on the clock. its an expensive car but its leased and the parents are going through a divorce so the mom can not afford to take it to the dealer. dealer was close to $2k for brakes all around.
If you only use the E brake when parked, there should be no wear. But I had to back off the shoes on my wife's old Subaru crosstrek for some reason, luckily the star adjuster was easy to get to and freed up.My rear rotors have the ebrake shoes on the back side of them. Never had them off in 130k miles. I'm sure the shoes will need backed off to get the rotor off.
I think even on a pad slap to be considered any sort of brake job you need to at least make sure the caliper pins are sliding freely, and possibly remove buildup off the hardware and relube. But OTOH I am sure some people dont.That is not a pad slap. If you clean the rust on the brackets and lube the pins and replace or clean and lube the spacers and shims in the working areas - that is a brake job. Just to give a surface to bed to I also file off the lip at the top of the rotor and take a grinding wheel on my drill and rough up the rotor surface a bit with a ziz-zag pattern across the face.
I had my first brake job failure recently with 20K miles on the pads, a inner pad jammed. It was due to rust build up on the bracket behind the shims and more critically, the replacement pad ears being too wide. I had to file the pad ears down to get a good fit. These were budget rear semi-metallic pads purchased at Autozone.
Rotors only get R&R'd when they are worn down to the inner turbine fins
For a paying customer, rotors would get an on car grind if servicable, but would be replaced with new factory rotors if worn below factory limits.
I would consider a pad slap pulling one caliper bolt, rotating the caliper up, prying out the old pad then inserting new pads, rotating the caliper into position and replacing the caliper bolt. NO cleaning or lubing or rotor massaging.
- Ken
- Ken
Exactly this.It depends on the situation. Generally speaking, if you are using the exact-same brand/model friction material and the rotor surface is smooth, it is fine. I am also assuming that there was no vibration prior to the brake service.
I did not charge them anything for it. i lost money with the brake cleaner and lube i used . Just wanted to help them out in tough times.If you're doing brake jobs for money without liability insurance you're a fool. A waiver just puts in writing that you did work, this could make it worse. You can't disclaim liability otherwise everyone would do it. IANAL.
I do front brake jobs because rotors are shot, rusted across half the pad interface, pads are jammed in the sliders, caliper pins aren't sliding that great. I get pads and rotors for most FWD cars for $45-60 from "Autoshack" on ebay, clean the hub faces, clean out the pin bores, grind the pad ears so they fit rust-jacked brackets. Clean and lube the pins and slap it all back together. Lasts the life of the car, or until I'm bored of it. No noise, great pedal feel.
I imagine many people do a good job on the outward facing side of the rotor while doing a poor job or even skipping the inside facing side of the rotor.View attachment 65169If I do a pad slap I always use these on the rotor. Most of the time it's just fine.
If you have a lip on the rotor surface, the rotor is either near/below minimum specs or will reach that point during the life of the new pads.Just to give a surface to bed to I also file off the lip at the top of the rotor and take a grinding wheel on my drill and rough up the rotor surface a bit with a ziz-zag pattern across the face.
