FlyingTexan
Thread starter
Was just comparing it to Redline/Motul/Amsoil/HPLIf you want a PAO base for whatever reason get something with Allison TES-295/TES-668 spec but realize you probably don't need it.
I have purchased it twice sitting next to the MaxLife multi …Not sure what the issue is here to be honest......It's a group III. So.........yes. It's fine. Add pack is waaaaaay more important.
I never said there was an issue. I just asked if it was a real synthetic.Not sure what the issue is here to be honest......It's a group III. So.........yes. It's fine. Add pack is waaaaaay more important.
If you like Amsoil, then just run their ATF for your vehicle. It’s an excellent ATF choice. That said, the Valvoline product is superb as well. Go with whatever brand you like. Both brands have a longstanding history of cult-like followings because those brands provided good alternatives to OE fluids when problems were arising with performance on OE fluid; but was noticeably better on these brands. That was like 20 years ago. If they delivered good results back then, I’d trust them today if looking for alternatives to OE because the track record has continued to this day.I do know that which is why OP asked in the first place. I asked if it was a true full synthetic. There are several that are and I know many make claims in the US but really aren’t. Redline, Motul, Amsoil, so far seem to be. After seeing the results of Amsoil gear fluid I was debating if when doing this change if I should just go all in on Amsoil.
I’ve used MaxLife for years in every Subaru I’ve owned at 20-30k spill & fills after I cleared out the old stuff; 4EATs & ML are almost tailor-made for each other. Never any issues.If you like Amsoil, then just run their ATF for your vehicle. It’s an excellent ATF choice. That said, the Valvoline product is superb as well. Go with whatever brand you like. Both brands have a longstanding history of cult-like followings because those brands provided good alternatives to OE fluids when problems were arising with performance on OE fluid; but was noticeably better on these brands. That was like 20 years ago. If they delivered good results back then, I’d trust them today if looking for alternatives to OE.
Interesting.I’ve used MaxLife for years in every Subaru I’ve owned at 20-30k spill & fills after I cleared out the old stuff; 4EATs & ML are almost tailor-made for each other. Never any issues.
However, last year I switched my ‘07 Impreza over to HPL Green CC, arguably one of the finest fluids available (I’ve used Amsoil ATL in other vehicles as well).
The Green is on the thinner side of recommended but in line with ML viscosity, but the transmission shifts smoother and quicker than it ever did on ML, and it also sharpened the takeoff from a stop. The ML would be almost “mushy” where you’d give the car gas & there was a slight delay. That is gone with the HPL; any throttle input results in much quicker and linear reaction.
Specs & clean fluid are more important than base oil composition IMO.
You should know the answer after eight years on Bitog wouldn't you say?I never said there was an issue. I just asked if it was a real synthetic.
No.You should know the answer after eight years on Bitog wouldn't you say?
I guess I classify an oil as full synthetic if it's made from fully synthetic parts like Redline, Amsoil, Motul, etc. I asked because I don't trust marketing and someone saying "Premium Full synthetic" made me wonder if it really is compared to it's neighbors. So it's no more a full synthetic than Liqui Moly oil saying they are. Everyone here bashes them because "They're not a real full synthetic" but somehow seem to gloss over it here. I wanted to know because Amsoil and other's market their product as one way and Valvoline is marketing this as if they put the same cost/effort into this when it isn't. Several here have mentioned the add packs. The Amsoil gear lube seemed to do much better on the bearing wear tests which is lower stress than the tranny. I guess some could say "i don't know why you're asking" and that's fine but I'm asking because if it's made from inferior base oils then I'd rather spend the money and going with top shelf. So many seem to get hung up on the cost of things. To me it doesn't matter, I want the best product. My question was part of finding that, not the end all but part of it. Do I really care if I spend $100 more over a 5yr period? No.It can legally be advertised as full synthetic. If your personal definition of synthetic is different I don’t know.
I'm sure you've heard of the boutique brands, that's where you'll find the "real" synthetics.
Again, I'm surprised after all this time you didn't know that.
Fully synthetic parts? What does that mean exactly? A Group III hydrocracked base stock is indeed assembled from smaller molecules, those are not synthesized but neither are those which compose a Group IV base either.I guess I classify an oil as full synthetic if it's made from fully synthetic parts like Redline, Amsoil, Motul, etc. I asked because I don't trust marketing and someone saying "Premium Full synthetic" made me wonder if it really is compared to it's neighbors. So it's no more a full synthetic than Liqui Moly oil saying they are. Everyone here bashes them because "They're not a real full synthetic" but somehow seem to gloss over it here. I wanted to know because Amsoil and other's market their product as one way and Valvoline is marketing this as if they put the same cost/effort into this when it isn't. Several here have mentioned the add packs. The Amsoil gear lube seemed to do much better on the bearing wear tests which is lower stress than the tranny. I guess some could say "i don't know why you're asking" and that's fine but I'm asking because if it's made from inferior base oils then I'd rather spend the money and going with top shelf. So many seem to get hung up on the cost of things. To me it doesn't matter, I want the best product. My question was part of finding that, not the end all but part of it. Do I really care if I spend $100 more over a 5yr period? No.
The answer is yes.I’m sorry but it’s not my fault you read this title and thought I was asking about boutique oils.
“Is Maxlife Extended Protection ATF a true full synthetic”
Then why did you repeatedly mention them?I’m sorry but it’s not my fault you read this title and thought I was asking about boutique oils
I didn't know what the base stock composition was hence me asking exactly the question I asked. It was a pretty simple question and apparently the answer is no. It is not a true full synthetic.I will go out on a limb here and say that your response isn't surprising to most anyone in this thread. It is likely what you wanted to opine when you started out. I doubt you really had a question in the beginning if you already knew what the base stock composition was and how it is produced.
