Same way. Liqui Moly is often unfairly put down on this forum. The reality is that they own and operate their own oil manufacturing facility and R&D center in Germany, ensuring full control over quality and formulation. While it's true they may not use GTL, they do offer oils that contain Group IV synthetics and esters, as well as high-quality Group III formulations. Many of their products carry approvals from like MB, VW, and BMW. Plenty of enthusiasts confidently stand behind Liqui Moly's productsBut again, if you're going LM and you're looking at value then why wouldn't you use FCP euro? You keep doing apples to oranges. I can do 7 quarts LM, Oil filter, air filter, and cabin air filter for $18. You're talking Quaker State Euro for $23 for 5qts only (and I like Quaker State Euro) but if anyone is going to mention the money aspect then make it about the money. If you're going to say an oil is inferior then stick to that. Don't say an oil is inferior due to the money. You're crossing two topics and there's a know remedy to that.
Besides the regular "Synthoil" (which has too high Noack for modern manufacturer approvals) what oils do they offer that are truly synthetic?While it's true they may not use GTL, they do offer oils that contain Group IV synthetics and esters
Vollsynthetisch. The german definition of full synthetic. I did not say 100% group IV.a bunch, also all SDS available www.liqui-moly.com
But for my BMW I was considering Special Tec B FE SAE 0w30 and Top Tec 4210 SAE 0W-30.
Both have 1-Decene PAO 30-60%
Also what you mean by "truly synthetic"? There no group IV only 100% oils commonly available
Why do you care about 40, if HTHS is >3.5 it is all good.Vollsynthetisch. The german definition of full synthetic. I did not say 100% group IV.
I didn't know about Top Tec 4210, that's an interesting one. Nothing similar in 40 grade sold here unfortunately.
An oil that starts at 3.5 won't be 3.5 after abuse. That very thick 30 grade will become a very thin 30 grade.Why do you care about 40, if HTHS is >3.5 it is all good.
Additionally Top Tec 4210 has viscosity about 11.9. it is a very thick W30 almost 40
No it will notAn oil that starts at 3.5 won't be 3.5 after abuse. That very thick 30 grade will become a very thin 30 grade.
There is thickening going on there, or that batch was much thicker than what pds says.
Every blender does that except "big boys," and some smaller oil companies who are in the business of drilling, etc. They sell base stocks and additives to companies like Liqui Moly.Same way. Liqui Moly is often unfairly put down on this forum. The reality is that they own and operate their own oil manufacturing facility and R&D center in Germany, ensuring full control over quality and formulation. While it's true they may not use GTL, they do offer oils that contain Group IV synthetics and esters, as well as high-quality Group III formulations. Many of their products carry approvals from like MB, VW, and BMW. Plenty of enthusiasts confidently stand behind Liqui Moly's products
Putting over way, if their oil products with all those approvals and cost like M1, Pennzoil, or Castrol and available at local Walmart, they certanly would have good number sales.
But they certanly DOA if there is no FCP LRG and sold for full price
I saw similar results after full VW recommended 12 K km OCI in VWs where Viscosity of LM did not drop.There is thickening going on there, or that batch was much thicker than what pds says.
Don't forget, blenders (any) put typical value. Just because that oil starts at 12.2cst does not mean you cannot have batch that has basically 5W40 in it (12.5cst). If it is 12.2cst, it dropped and started to thicken.
You can enable auto translation and see viscosity check at 3:00
And I assume it is with bad quality high sulphur gas
https://www.liqui-moly.com/de/de/top-tec-4210-0w-30-p005106.html#21604a bunch, also all SDS available www.liqui-moly.com
sdshttps://www.liqui-moly.com/de/de/top-tec-4210-0w-30-p005106.html#21604
Seems unlikely
"Hightech-Leichtlaufmotoröl auf Basis Synthesetechnologie"
4210 has older additive pack, not new additive pack. Group III base stock pack that is common with API SP additives is much better than before in Castrol, Motul etc. which gives them pour point as low as -45c. 4210 has pour point of -47c.
how do you read that in his UOA?There is thickening going on there, or that batch was much thicker than what pds says.
I don't care.. As you saw from my earlier post LM sells this product in Germany as "synthetic technology". It's no different than M1.
KV100 is too high for that mileage. It probably sheared, started to thicken than. Unless it is km. But if it is km, oxidation is bit high then too.how do you read that in his UOA?
You are talking about KV100, not HTHS. Your KV100 is thickening due to volatile low-quality bases.No it will not
It is bmw long life approved
I personally used LM long life high tech with LL04 approval in my g37 for over 5K miles and sent to BS. The viscosity still was above 11.
That vq37 engine is running hot and known for searing engine oils like crazy.
LM uses high quality Viscosity improvers
